Civil 3D Forum
Adding branch fittings to two pipes in same network - not working
8 REPLIES 8
Message 1 of 9
swartaZ6NR2
362 Views, 8 Replies
Good day,
I have created a pipe network (only one, if I'm not missing anything) with numerous pipe runs. However when I want to add a T-Piece branch fitting, it does not do it and gives an error message stating the two pipes are not in the same network. But I am sure I created just one pipe network with various pipe runs.
Second question - I initially had an intersection (T-shape) with three separate pipes, which did not work for adding a branch fitting, thus I stretched the one pipe longer so that the T-connecting pipe, only connects to one pipe. Is there a way to connect three pipes at a T-junction?
Thank you
A
Labels (1)
8 REPLIES 8
Message 2 of 9
RobertEVs
in reply to: swartaZ6NR2
I had this happen to me yesterday. Audit the drawing, save, close and re-start civil. My pipe run branch fittings started to work again. That is assuming they are in the same network BUT two separate runs.
Message 3 of 9
swartaZ6NR2
in reply to: RobertEVs
Hi Robert,
Thank you, I tried it, but unfortunately I still have the same error message.
I will continue to search for more possible solutions.
Thanks again!
Message 4 of 9
RobertEVs
Can you post the dwg? Are you sure they are two separate runs you are trying to branch? Another reason they will not branch is that there is not a suitable tee fitting in your parts list to use
Message 5 of 9
swartaZ6NR2
Hi Robert,
I actually started again from scratch, to see if it will make a difference if I don't split the whole pipeline up into too many pipe runs. But is still gives problems. I am attaching a file which is closest to the file I was having the problems with. You'll see there is three pipes connecting at a tee and it cannot get a fitting placed there.
Will appreciate your comments.
Thank you
Message 6 of 9
RobertEVs
Problem is that the two linear pipes are in two different runs. you actually have 3 pipes and 3 runs. Branch will only connect 2 runs. You can instead add a fitting and connect each pipe to it. Using your drawing here is a screen shot
Message 7 of 9
RobertEVs
Even if you did have a single long pipe run and another perpendicular run they would not branch because in your drawing parts list Pipe Long=250 dia. and Pipe Perp=200 dia. You do not have a tee fitting 250x200 that will work so it would never place one there.
Message 8 of 9
swartaZ6NR2
Oh, thanks! Now it makes sense! I will have to fix the parts list before I continue. Thank you very much!
Message 9 of 9
RobertEVs
NP. Please except message number 6 as solution.
Rail Community
