Add Volume Surface
Add Volume Surface
bnagel
Message 1 of 9
Add Volume Surface
bnagel
I cannot seem to get the Add Volume Surface to display in Volumes Dashboard. I have two surfaces created and just need to do a volume report for undercut of dirt.
I have tried restarting the program several times.
Thanks in advance.
Replies (8)
Message 2 of 9
tcorey
Are both of the existing surfaces TIN surfaces or might one be a Grid surface?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
bnagel
They are both TIN. The issue is from the Panorama dialog box, I can't access the "Add Volume Surface" command. It is greyed out.
Message 4 of 9
joantopo
Try creating a surface volume previously from the tool space.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Message 5 of 9
Pointdump
B,
Please post your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 6 of 9
BrianHailey
Just grasping at straws here, did you select the volume surface first in the dashboard? If there are multiple volume surfaces, it needs to know which one to create the report for.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 9
bnagel
I'm still learning all this so, not sure if I completely understand
Message 8 of 9
I'm not sure how this is an answer. From the way your question reads it appears that you were having the same issue that I am having now. I have two existing tin surfaces. One design and the other background. I would like to run a report to figure the dirt quantities but when I pull up the volume dashboard, no surface is showing. The list is completely blank and the button to add and existing surface is grayed out. Has anyone figured out how to fix this?
Message 9 of 9
BrianHailey
Hi Jason, and welcome to the forums.
The volumes dashboard will only allow you to add volume surfaces to the dashboard, not regular TIN surfaces. You'll need to create a volume surface first and then the button to add a surface will not be greyed out. Alternatively, you can use the volumes dashboard to create the volume surface directly (it's one of the buttons near the add a volume surface button). This is the way I typically do this. Just remember when you create the volume surface, the "base surface" is the surface that was there before and the "comparison surface" is the one that is there after.
GEI Consultants
My Civil 3D Blog
