Civil 3D Forum
Add/Show Line Gradient in the Properties
8 REPLIES 8
Message 1 of 9
Ivan_Cosmai
253 Views, 8 Replies
Hi. Is there a way to show the gradient of a line in the properties panel in Civil 3D? If not, it would be quite useful to show this as it could have quite a few benefits (e.g. checking pipe gradients without having to built a network, checking slopes without having to create labels etc.).
Labels (1)
8 REPLIES 8
Message 2 of 9
Jeff_M
in reply to: Ivan_Cosmai
If you have the Sincpac-C3D add-on package and have the EntityTracker palette open you would see this when hovering over a line:
Jeff_M, also a frequent Swamper
Message 3 of 9
Ivan_Cosmai
in reply to: Jeff_M
Thank you very much, Jeff. I note the package is not free, so I was hoping there would be another way of enabling that extra box in the properties.
Message 4 of 9
AllenJessup
Since the Properties Palette is basic AutoCAD. I don't know how the grade could be added.
Allen Jessup
CAD Manager - Designer
Message 5 of 9
Ivan_Cosmai
in reply to: AllenJessup
Well, yes, but it still gives you Delta Z and length, which is all you need to work out the gradient. It should be a default option as it's quite useful.
Message 6 of 9
AllenJessup
I do agree with you. I looked into the CUI to see if it could be added to Quick Properties but it's not available. No way I know of to use and expression.
The quickest way without Sincpac, which we use, is to use CGSLIST.
Allen Jessup
Message 7 of 9
Ivan_Cosmai
Hi Allen! CGSLIST is actually really good, thank you! I like that it gives you both the slope and the gradient, so two different formats.
I tried to add it to my command aliases so I wouldn't have to type it in full every time, but Civil 3D doesn't let me do it for some reason - see attached screenshot. The command clearly works when I type it in full, so I wonder if I'm doing anything wrong... Thank you!
Message 8 of 9
AllenJessup
IN 2024.3 I added it to my acad.pgp file as
SL, *CGSLIST
and it works.  G being for Group may be an alias you can't overwrite. SL defaults to Slice but I had no problem replacing it. If you edit the PGP file remember to REINIT to test.
To see where your PGP file is use = (findfile "acad.pgp")
Allen Jessup
Message 9 of 9
Ivan_Cosmai
That worked perfectly, thanks very much!
Rail Community
