Add objects to Alignment
khd.civil59
Message 1 of 8
khd.civil59
hello,
I want to add an objects to the Alignment. The desired item does not include the line and the arc
thank you so much
Replies (7)
Message 2 of 8
Alfred.NESWADBA
can you please upload the dwg-file, at least to see which object types you try to add to the alignment and then also to see the exact message you get.
Sometimes it's simply the reason that a polyline you want to add is not drawn in the same direction as the alignment, reversing the polyline would help in that situation.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
MMcCall402
That is the correct tool for adding Autocad elements to an existing alignment.  Its not my normal practice so I did a little test and noticed that initially I had to press the tool button a second time before it prompted for the selection of the objects to be added.
If the alignment labeling doesn't continue into the new segments is just means that their direction needs to be reversed so they're in the same direction as the rest of the alignment. The tool for that is the next button to the right of the one used above.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 4 of 8
khd.civil59
hi,alfred
I want to go through choosing the object
thank you
Message 5 of 8
Alfred.NESWADBA
Understood that, but to know why your selection is ignored or to understand what happend then (after you selected your object) it needs more informations, e.g. the dwg-file, or screenshots of your command line to see the message or a screenshot of the property window to see which type of object you try to add to the existing alignment.
- alfred -
Alfred NESWADBA
Message 6 of 8
Joe-Bouza
Easier to the end then the start
they have to be lines and arcs
Joe Bouza
Message 7 of 8
khd.civil59
hi,
Message 8 of 8
Joe-Bouza
“The Object” has to be lines and arc.... ONLY
and it would be best if they are created in the same direction as the alignment.
since The Object has to be drawn somewhere somehow, why not just use the alignment tool bar to draw The Object
Joe Bouza
