I want to drape a polyline over a surface (create feature from object) but also would like to add vertices on the polyline before draping. It's been awhile since I've done this and don't remember how. Could not find this in a search either.
Civil 3D 2014
Civil 3D 2014
Solved by klugb. Go to Solution.
Mark Green
Working on Civil 3D in Canada
Mark Green
Use the modify feature line (even though it's not a feature line it will work).
Insert PI
Increment (I used 10')
That's it.
Insert PI
That's it.
specific increment
will this update the elevations with the surface? have not tried increment on a feature line before.
Well I see @klugb guessed it & got there first!
See above. Nice picture!
Mark Green
Mark Green
Mark Green
Mark Green
yea took a second to think about it (what i should have done first) and that was what i figured.
Too bad that didn't work on the powerball ticket!
It will be more accurate to set increment first then use the "Set elevations from Surface" and make sure to turn off the "Insert intermediate...." toggle.
If that worked for powerball then I could use the Accept Solution for Life button
Thanks for the help. Sorry I didn't before.
Thank you!!
