Does anyone know if the editing of multiple vertices has been fixed in Civil 3d 2018?
Solved by chriscowgill7373. Go to Solution.
Solved by Jowennl. Go to Solution.
Yes, it has been fixed.
Please get the patch <here>
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
There is the hotfix that @Jowennl gave you the link to, but it is my understanding that the fix was included in the Map3d 2018.0.1 update. can you confirm that you have all of your updates installed?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
This fix appears to be for Map3D. Is there a fix for Civil 3D 2018?
Thank you,
Civil 3D is built on Map, and it was a Map bug, so that is the fix.
Excellent! Thanks for the quick response. I have installed the fix and can confirm it works for me.
