ODEdite plugin inhave installed but i cannot see in the ribbon how can i get that?
Solved by Udo_Huebner. Go to Solution.
Solved by DarrenP. Go to Solution.
contact the developer of the add in:
DarrenP
Thanks for sharing this information. Then you simply have to use Civil 3D 2020, in cases where this plugin is important for you.
