Sorry Neil, the point is you have to add the grading surface. Gradings
stand alone like corridors no?
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"neilw"
wrote in message
news:6039244@discussion.autodesk.com...
I'm not understanding how that relates to the topic John. I want to add
gradings to my design surface. So far I don't see a way to do it.
"John Mayo" wrote in message
news:6039175@discussion.autodesk.com...
Hey Neil,
Create a new surface. Paste Eg in and then paste the grading surface in.
John
"neilw" wrote in message
news:6038955@discussion.autodesk.com...
Never mind on the tesselation question. At first I thought you could not
change the setting without deleting the surface but it turns out the surface
model will update if you manually rebuild after changing tesselation
settings. For some reason the surface will not update automatically when
tesselation is changed for gradings.
news:6038806@discussion.autodesk.com...
A related subtopic: If I have to create a surface from a grading and I add
feature lines and points to flesh it out, how would I change the tesselation
of the grading surface? It looks like I would have to delete the surface
which would wipe out all my supplemental work. Is this the case?
news:6038653@discussion.autodesk.com...
I know how to create a surface from gradings, but how can I add gradings to
an existing surface? If I start out with a surface built from points,
feature lines and other entities, how would I add gradings to it?
