add feature line to surface
Message 2 of 10
I want to add a feature line to surface. When I select and right click a feature line, there is no "add feature line to surface" option??
Replies (9)
Message 1 of 10
Message 3 of 10
J.FOCHT
You could try it this way:
  1. Go to Toolspace
  2. Expand the Surfaces section
  3. Expand the surface that you want to put the feature line on
  4. Expand the Definitions section
  5. And Right Click the Breaklines option
  6. You will then have a dialogue box to set some settings for the breakline
  7. You can then select the feature line and add it as a breakline.
See if that will work for you!
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
Message 4 of 10
J.FOCHT
See this thread for same discussion:
https://forums.autodesk.com/t5/autocad-civil-3d-forum/add-feature-line-to-surface/td-p/7616934
Thank You!
Jonathan Focht
Message 5 of 10
civilman1957
Feature lines are added under "breaklines" onto a surface...
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 6 of 10
rkmcswain
Try setting PICKFIRST = 1
Message 7 of 10
rkmcswain
Message 8 of 10
thanks!
By the way, what is the meaning to set PICKFIRST to 0? why the program change this number for me without permission?
Message 9 of 10
rkmcswain
A lisp file or other customization file could have done it. No way to know unless you catch it in the act.
If you are on 2016 or later, you can use the SysVarMonitor to watch it.
Another option is to use a reactor to watch for it and switch it back immediately, like this: http://cadpanacea.com/wp/?p=971
Message 10 of 10
jmayo-EE
One more scenerio to add to R.K.'s comments.
If a command temporarily overrides any system varable and you crash mid command, the variable may not be reset to where it was.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
