Add additional sample line to existing sample line group (Tip)
doni49
Mentor Mentor
doni49
I just did this and thought I'd pass on the tip.
An excerpt from the link:
Have you ever created a group of corridor section views, done a bunch of labeling edits to your automated code set labels; and then find out you need to add a few sections right in the middle of the sample line group? Now you have to spend a bunch of time recreating a new sample line group, re-cutting the section views and making annotation edits all over again, right? Nope. You can actually add sample lines to an existing group right in the middle of the same sample line group using..........
http://envisioncad.com/tips/autocad-civil-3d-tip-adding-sample-lines-in-the-middle-of-the-existing-s...
EDIT:  After the new sample line was added to the group, I did have to manually edit the NAME of the new sample line.  But that was easy enough using the PROPERTIES of the SL.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Thanks for the tip! It saved me a bunch of time :).
mathewkol
Or use 2018 🙂
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
marie0394
Hello @mathewkol
I know it's an old question but I can not find another way to do this. What would be the other way to do it? My office uses the 2019 version.
