I am working in Auto cad Civil 3d 2011.
Is it possible to add a .tiff imagery and keep the same coordinates format.
Solved by Pointdump. Go to Solution.
Solved by Joe-Bouza. Go to Solution.
Joe Bouza
Elie,
In addition to Joe's excellent advice, you can also use _MAPCONNECT:
Dave
Dave Stoll
Las Vegas, Nevada
Not that I know of but 8gigs will choke most systems to a standstill.
Can you post a bigger screen grab of the command line history, and one of the folder contents where the tiff is located?
Joe Bouza
Elie,
Size is not the problem there, although that's a seriously large Tiff. Looks like a formatting problem with the file. Where did you get the Tiff?
Dave
Dave Stoll
Las Vegas, Nevada
Elie,
Where did you get that monster? If you have IrfanView, GeoViewer, MicroDEM, or OpenEV, you can check to see if it's a valid TIFF.
Dave
Dave Stoll
Las Vegas, Nevada
