That's Bing imagery you have uploaded. If you want to use georeferenced images that have better resolution, you'll need to use a third party software such as Plex Earth, which you'll have to purchase. You can find it, along with various other apps in the App Store. In the ribbon go to Featured Apps tab=>Connect to App Store Icon. For Plex Earth, search for 'Aerial Imagery' while in the search box.
You can also download free aerial imagery from online sources. Here is an example:
https://earthexplorer.usgs.gov/
- In search criteria tab choose, 'Use Map' then zoom in to your area of interest. 'Frame your image' in the view you see on your monitor. On the web page, you can ignore the other settings and stuff, it's all noise.
- On the bottom of the panel that's docked on the left, click Data Sets.
- Expand Sentinel, click box next to Sentinel, then at bottom, click RESULTS. Choose your image(s) and click the download icon.
You may also, if you wish, go to Additional Criteria tab and select cloud cover. The smaller the percentage, the less cloud cover your image will have. These images work well for big, wide areas were you are zoomed out far, far above your site. If you want an image for a small, tight area like the asphalt driveway at your house between your garage and sidewalk, then this type of image may not be feasible. You may also try other images besides Sentinel. Sentinel seems to be the most current and seems to provide the clearest imagery. The Sentinel images are FREE and you can't argue with free.
Chicagolooper
