Is there any way in C3D to get a volume calculation in acre feet instead of cubic feet?
Rick Jackson
Survey CAD Technician VI
Mark Green
Working on Civil 3D in Canada
I guess to be more precise, where would I put the expression?
I would like to have it in a surface table.
Seriously. 🙂
The initial post discussion was what I'm looking for, but the discussion degenerated into a debate on imperial vs metric units.
There was never an answer to the question.
Mark Green
The simple way is just type the conversion factor directly into the volumes dashboard, so instead of cut and fill factors of 1.000 change them to the decimal your're after. So if your dashboard is currently showing cu ft., type in 0.00002296 for the cut and fill factors and check the result.
[edit] if you need more decimals go to the drawing settings. Or if you want to be specific, edit the VolumeDashboard Surface command settings
Cheers
- Mick
