ACAD Export - Layers
TOONFANCC
TOONFANCC
I use the object layer suffix (detailed here) so my corridors, surfaces etc. have a unique layer name which makes it easier to freeze off certain elements of the model.
To allow other users in my office (who don't have Civil 3D) to view the content, I export my drawing to an ACAD format. However, this loses the unique layers, i.e. all of my corridors appear in C-CORRIDORS, not C-CORRIDORS-Road1, C-CORRIDORS-Road2 etc. Is there a way to export my drawing to ACAD whilst maintaining the layer names?
rl_jackson
I can't think of a way you can do that, the think is the objects style have the layer of the style, you just telling the object to be on the suffix (or prefix) layer.
Perhaps, using a Object Enabler, vs exporting might help the plan ACAD user, this way your objects are intact, they can view and see them, but can't edit them.
Rick Jackson
Survey CAD Technician VI
cwr-pae
I have never used the auto naming layer function, so I'm not positive of this: but if you manually explode a C3D object, it remains on its current layer, this may be what you need. CTL+A to select everything and explode. This should also effectively "export" the drawing to ACAD.
wpagl452
Hi @TOONFANCC thanks for your forum post!
What versions are you using? I just made some dummy suffix layers for a few corridors in C3D 2019, exported to ACAD, and they retained their unique layers. I hope I'm understanding your workflow correctly. As @cwr-pae mentioned, exploding the objects should work as well, but they will read as blocks instead of AECC objects once in ACAD.
Let us know if we can help further.
All the best,
Winston
wpagl452
Here are some methods to retain unique layer names for Civil 3D objects when going from Civil 3D to AutoCAD.
1. As was mentioned above, explode the object. Export to AutoCAD filetype. In AutoCAD, block retains unique layer name. Undo the explode in Civil 3D.
2. Slight spin on the first way. Copy the file, explode the object to a block and just open using AutoCAD. Block in AutoCAD retains unique layer name. This second method doesn't use export and avoids touching the original Civil 3D object file.
3. Copy the file and open using AutoCAD. Object is identified as AECC object in AutoCAD with unique layer name retained. This method also doesn't use export and avoids touching the orignal drawing.
Simply exporting a Civil 3D file with AECC objects to AutoCAD will result in the object being broken down into it's base components (similar to exploding twice). In the case of a corridor, the object is exported as lines and 3D polyines that are on the layers set by the corridor style in Civil 3D.
All the best,
Winston
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
