Absent pavement?
Absent pavement?
ekoneo
Absent pavement?
ekoneo
Hi All.
I prepared two corridor. One of them is main corridor. Another one is secondary corridor. I produced sample lines depending on main road's axis. And then I drew sections. But Secondary road's 3th structure is absent. Interestingly first and second structures are available. You can see my assembly and section result on atached photos. Why this problem occured?WhyStructureAbsent2.png
3th Darkgreen pavement is available at both sides. But section dosnt show us the 3th pavement.
Jeff_M
Check that the depth of each of the layers is the same for all adjoining subassemblies.
You may get quicker help if you post the drawing.
ekoneo
Thanks Jeff_M. I added my sample work. I havent find solution yet. Becouse I couldnt understand the source of the problem.
My work is here:
https://we.tl/llVXBFSVei
Pointdump
E,
Please post your drawing directly here instead of a link to a Dropbox-like site. This Forum will accept files up to 75 MB. You can even zip several files together.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
ekoneo
Thanks Pointdump,
I atached here.
