3D solids following surface height
met1ns
met1ns
Hello!
Is there a way to give a rule to 3d solids so its 1 meter under my surface at all time?
If not, can I do it to 3d polylines? Feature lines? Then convert it to 3d solids.
Thank you!
tcorey
You can do that with Feature Lines and their elevations will remain dynamically linked to the surface, at any +/- value you give it.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
met1ns
Thank you!
So now I do have feature lines at correct height.
But here is the issue.
I want to sweep it to 3d solids. But I cant sweep feature line. I tried exploding it to 3d polyline and sweep it, same result... Any iddea what I can do?
The end goal is to get 3d solids at correct height and shape.
met1ns
I managed to find the solution to that problem. I had to uncheck "Insert intermediate grade break points." Now Im able to sweep my 3d polylines that I have exploded from the feature lines.
When I draw the size of the rectangle that I wanna sweep the 3d polyline from, which point of the rectangle gets it sweeped from? Top, midd or bottom point? So I get the correct height.
Thank you.
