3 point angular dimension
This widget could not be displayed.
Go into your angular dimension command by typing DAN and hitting enter.  Hit enter once more to specify vertex.  Select the endpoint/intersection of the two lines for the vertex, select the two endpoints/points on line of the two line segments that you're getting the angle on and place the dimension.
