2D Road Markings onto Surface
RupinderWilkhu
Message 1 of 10
RupinderWilkhu
Greetings,
Anyone got any advise on how to 'drape' Road Markings (at 2D elevation 0) onto a Surface.
The Road Markings are a combination of blocks, hatches, text and polylines.
Replies (9)
Message 2 of 10
ecfernandez
Hi there, you can convert all your markings to individual blocks and then use the "Elevation from surface" tool to pull them onto the surface.
Regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
Message 3 of 10
VincentSheehan
Maybe setup a Feature Line style as road markings. As you create the Feature Line, assign it to the surface. Explode it to a 3D poly if needed.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 4 of 10
Ann-Marie_Valois
How about this workflow?
1- Use infraworks to create your striping on the surface
Create an FDO database connection in Map 3D or Civil 3D to the InfraWorks model sqlite database to connect to the coverage data
  • Extract the coverage data to polygon
  • Edit the polygons in Civil 3D or Map 3D
https://youtu.be/RSO1heQujys
Message 5 of 10
ecfernandez
Thanks for sharing @Ann-Marie_Valois, that is a really good option. Best regards!
Camilo Fernández
LinkedIn
Message 6 of 10
RupinderWilkhu
Many thanks to all those who responded. much appreciated.
We went with the option to convert the elements to blocks and then move to surface.
Message 7 of 10
laiywL6WMR
Observer
Observer
Hi,bro, I have confuse about that how to  use the "Elevation from surface"tool ,could you tell me how  can I this function,pls?
Message 8 of 10
ecfernandez
Hi @laiywL6WMR, just select the surface you want to project your blocks on, and then look for this button on the ribbon
Use the "Move blocks to surface" option.
I hope this helps. Best regards!
Camilo Fernández
LinkedIn
Message 9 of 10
laiywL6WMR
Observer
Observer
Dear Camilo Fernández,
hi,thanks for your help.
Hope you are having a great week!
I am writing to sincerely thank you for the solution you provided in your blog post regarding  2D road markings sign onto surface.Your step-by-step explanation was exactly what I needed, and it helped me fix the issue I was stuck on.I really appreciate the time you take to create such clear and helpful content. It makes a huge difference for readers like me!
Thanks again for being so generous with your knowledge. Keep up the awesome work!
Best,
Yeven Lam
Message 10 of 10
ecfernandez
hey @laiywL6WMR, thanks for those words. I truly appreciate it 😃. Happy to help and a good day!
Camilo Fernández
LinkedIn
