Civil 3D Forum
2024.2 UPDATE - PERFORMACE DEGRADATION
8 REPLIES 8
Message 1 of 9
fcernst
522 Views, 8 Replies
Has anyone else noticed a degradation in performance after installing this update?
I have projects with large Volume surfaces with MMS ancillary files where we do surface elevation analysis on and they are taking forever.. can't work like this.
Is there a way to uninstall this update now?
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
Labels (2)
8 REPLIES 8
Message 2 of 9
TimYarris
in reply to: fcernst
Hi @fcernst,
I'm not aware of a performance degradation, but I'll ask the team to research ASAP. Would it be possible to provide a data set for us to validate?
And would you please let me know the build number of the Update you have installed? Asking because we just reposted a new 2024.2 Update yesterday (after taking the previous one down on Oct 11).
Message 3 of 9
brian.strandberg
Installed the update yesterday.  I use a script to test drawing load performance, I'm getting almost the same time to open the drawing. (2024.2, 38.1 sec; 2022.2.5, 39.1 sec), but this isn't a large dataset (about 30 acres).
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Message 4 of 9
fcernst
in reply to: brian.strandberg
Yes.. we're at a 7,500 acre watershed level..
Try modifying the Comparison surface.. then rerun the Elevation Analysis for one range.. then modify the elevation range..
Fred Ernst, PE
C3D 2025
Ernst Engineering
Message 5 of 9
fcernst
in reply to: TimYarris
Yes the new one.. never installed the first one
Yes I can send you a link to a dataset over the weekend. Thanks Tim
Fred Ernst, PE
C3D 2025
Ernst Engineering
Message 6 of 9
TimYarris
Many thanks for sending the data set, @fcernst . We'll take a look and let you know what we learn.
Message 7 of 9
neilyj666
Are we better to hold off installing this update for the moment?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 8 of 9
fcernst
Thanks Tim..
I have another data set consisting of a simple Corridor with four simple bowties that won't cleanup that hopefully you're team can look at in regard to the this latest update.
Fred Ernst, PE
C3D 2025
Ernst Engineering
Message 9 of 9
brian.strandberg
@fcernst I'm curious if you have level of detail on or off.  I have done some testing with a surface large enough to trigger an mms file, with Level of Detail OFF.
Surface is 1.03 Million Points, and I'm getting better performance with 2024.2 vs 2022.2.5.
Rail Community
