For some reason 2019 is randomly (I believe when opening XREFS from inside another drawing?) is removing the CAPLOCK from the drawing name. Highly annoying. Anyone else noticing the same?
Solved by wpagl452. Go to Solution.
What do you mean by "CAPLOCK"? Are you saying that the drawing name is changing to lower case letters from the original drawing name being in upper case letters?
Hi @M!chelle. Thanks for your forum post!
This is an issue we've seen before. Using XOPEN can cause file names to be written in lower case. This has been identified as a server issue (we do not support SAN or NAS hard drives).
I wish I had better news for you on this matter, but know that this is not a sign of drawing corruption.
