2018 Productivity Tools for C3D
Message 1 of 8
Hi
Am needing to covert DWG to 12DA. This conversion tool is in the 2017 Productivity Tools however there is no 2018 Productivity Tools that I could locate and 2017 MSI wont load. Ideas?
Regards
Andrew
Replies (7)
Message 2 of 8
M_c3d
Productivity tools aren't available for 2018 yet. Can you be more specific with the problem from the 2017 tool?
Message 3 of 8
If you have 2018 installed and you try to open the 2017 MSI a dialog comes up saying cant be installed into 2018.
Message 4 of 8
M_c3d
yes that's correct they are completely different pieces of software, you can't install a 2017 add on into 2018
Message 5 of 8
bryan.garnett2
Observer
Observer
Any idea on an ETA for this?
Bryan
Message 6 of 8
M_c3d
should be any time now, but word is there has been some delays for adding new features and testing
Message 7 of 8
mer123456
It is August 28 th, 2017 - I can't find them.  Are they out yet?
Message 8 of 8
bmorse
I could not find the command in the ribbon but did find a list of Pipe Network commands in the help system.  ConvertTo3DSolid is the command to execute while you have your model in a 3d view like SW (not plan view) with view style set to Conceptual or Realistic.  The 3D solids representing the pipe network objects are inserted into the current drawing on the same layer.  There is no attribute data attached to the solids.
 Civil 3D Pipe Network StructureCivil 3D Pipe Network Structure3D Solid3D SolidThe structure and the solid occupy the same space on the same layerThe structure and the solid occupy the same space on the same layer
