2018 corridors refuse to accept transition alignments
annw2
Message 1 of 25
annw2
I am starting another corridor in 2018 and again the corridor is refusing to attach transition alignments.  It says it will, then ignores them.
Last time I had to port it back to 2016 to get it to work.
Ann Wingert, P.E.
Replies (24)
Message 21 of 25
annw2
I sent the corridor out to our consultant.
He got the third area in the middle with the sidewalk & basic lane to work.
I tried the first section with the super elevation lanes & just links and they won't attach.
Our guru says that if he selects the corridor and right clicks, it won't work.
I tried that the the select corridor from the tool space and it won't their either.  If I try to right click the corridor, it won't work.
I tried the modify corridor from the top ribbon and that won't work on the first section with the assembly with the super elevation.
Ann Wingert, P.E.
Message 22 of 25
Joe-Bouza
Hello Anne
Not to bum you out but I just installed 2018 with all the sp's and the targets worked.
If I may ask; what is your work flow for intersections? I've never been able to data ref and do a lock profile
Joe Bouza
Message 23 of 25
annw2
i don't do that many intersections.  When I do I follow the procedures in the Mastering Civil 3d book series.
I haven't had to use the profile locks.  I make sure the intersecting roads agree and back off the cross sections from the intersection.  Then I use alignments along the curb return.
The file is behaving very strangely.
I can easily add the profile targets, but it won't accept the horizontal ones.
Ann Wingert, P.E.
Message 24 of 25
Joe-Bouza
Have you tried a repair on you install and add the sp's?
sorry if I am making you repeat yourself
Joe Bouza
Message 25 of 25
annw2
I am not allowed to do repairs on our server.  I asked our AutoCAD IT to look at it.  It didn't work on a co-workers computer and our IT is having issues on his computer as well.
When I posted what was installed, the reply back here said that I had the latest install.
What is weird it that it will take the profile target, but not the horizontal.
I also had issues on another 2018 file - that last one I did.  It worked fine in 2016. Bad template?
Ann Wingert, P.E.
