2 Corridor issues
2 Corridor issues
michaelV7UU9
2 Corridor issues
michaelV7UU9
I am creating a corridor that targets BLVD offsets to inside sidewalk alignment and then has a standard 6' wide S/W.
1-For some reason, the middle of the corridor is not following that code.
2- the surface created from the corridor does not fully fil the corridor, but instead peters out oddly. sidewalk missing.jpgsurface.jpg
Happy to supply more info if needed.  project due in 2 weeks and I'm trying to get a jump on this before the new year.  Any help or suggestions would be great.
Accepted solutions (3)
tcorey
Can you post your drawing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
michaelV7UU9
Here is the CAD file. also of note, when I pull the corridor to the end of the alignment on the east end, the surface drops to zero(0).  Appreciate anything you might come up with.
Jeff_M
The sidewalk issue is due to your 2 target alignments cross into the curbs. Edit them so they do not cross and all will be well.
The tapering surface is due to one of the Surface Boundaries definitions having the Reverse option checked. Uncheck this to get the surface to create correctly.
michaelV7UU9
Thanks. I fixed the sidewalk but am unclear where I uncheck the reverse option. I did remove the boundary and that solved it but that the surface is outside the corridor. Can you describe where i uncheck the reverse?
Jeff_M
michaelV7UU9
Thanks. I noodled around and found that.  It was automatically checked and I did not know that field even existed. learn a lot thru this and am grateful for your assistance.
