I was wondering if someone out there could help me confirm that the sample VBA sheet set manager code provided with Civil 3D does not work correctly, or if Autodesk's intent was not to provide a usable code example for the sheet set manager. I have tried it using two computers at work and on the free trial version of AutoCAD 2007 at home. The project should be located on your computer at:
C:\Program Files\Autodesk Civil 3D 2006\Sample\ActiveX\SheetSetVBA
I am able to run the "Example_SSC" correctly except for the part where it is to add custom properties to sheet1.
The Example_SSListAll does not list the custom properties as the code indicates that it should. It will list the subset, name and description correctly.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
