- Mute
- Permalink
- Report
Hello all,
I have been doing some searching and have not yet found anything. I am trying to find or make a way to toggle all of the layers in a drawing that contain cogo points on and off. I calculate points for our survey crews so I'm constantly working with them. Unfortunately, my company does not have a hard and fast layer naming convention for cogo points so they can end up on any number of layers, with any name.
My ultimate goal is to have a single button on my tool bar that when I click it, it turns on and thaws every single layer in the drawing that contains a cogo point. then when I click it again it will freeze every layer that contains a cogo point.
I can see some potential hiccups in that blunt of an operation though. Like if a layer containing a cogo point needs to remain on for line work and other objects, but the cogo point has a style that puts the label and/or marker on a different layer that could be frozen thereby hiding the cogo point label and/or marker.
How would you recommend I create a button like that?
I have a limited knowledge and experience with AutoLISP so hopefully in your reply yo can simplify things so I can learn.
