Hi everyone,
in my drawing line line and curve segments are not functioning properly showing wrong result. my alignment is 5.00 km but its not showing the same. can some one help me the same.
Solved by Neil.Aryan. Go to Solution.
@Anonymous
If the drawing is created on default CAD template this error will appears. check the civil 3d drawing units or civil 3d annotations units and change to metric to get the correct figures.
if you are having issue to fix the same feel free to share the file so that can check and fix the same.
Neil
Project Manager | Civil | ACE Inc.
Certified Civil 3d Professional | YouTube | My-Blog
the drawing units in meter but civil 3d annotations are showing feet. if i change this to meter i am able to see the right answer. but the problem is have many labels in one drawing and takes too much time is there any way to fix this ?
you can use command _ImportStylesAndSettings to import all standard styles and setting from the template drawing.
but I would suggest you to copy all objects from current drawing and past into default civil 3d metric template or any standards template automatically everything will converts to metric and result will be correct.
Hope this will works for you, if not feel free to upload the drawing to check and find the solution.
Neil
