Hi, I am trying to create a custom command in the CUI that will help me create spot elevations faster.
I can use the command CREATEPOINTSLOPEGRADEDIST to create my new point at a specified grade from a reference point, but there are so many prompts that I find the command is not so usefull for me.
My command string is currently as follows: ^C^C._AeccCreatePointSlopeGradeDist;nod;\\G;\;0;0;Y;;
I have spent an inordinate amount of time trying to get this to work, but can't seem to nail it down. When performing the command manually here are the steps:
1. Snap to the node of a point (this will ensure I get that point's elevation)
2. Choose my new point location.
3. use G for grade and enter my grade.
4. hit enter to skip choosing a distance (this will use my prevuously selected point)
5. use 0 points in between, 0 offsets, Y for endpoint, and no description.
Then I arrive at my new point as I would like, for some reason I can't replicate this command in the CUI. Any help is really appreciated.
Thank you.
Solved by kmohs. Go to Solution.
Thanks, the command works, but for some reason the point is not showing up...
I have resorted to writing a custom .NET command - hopefully I will get something working.
