Hello everyone,
Is there a way to split the surface? other than by bondary method with select in or outer bondary?
apart from using plugins?
i will split surface one time with difference rectangle.
thank you.
Have you tried CREATECROPSURFACE Command?
"How we think determines what we do, and what we do determines what we get."
you can keep the original surface, and use paste surface for new surfaces with boundaries for the new surfaces, so the original surface stays the un touched .
