I have a LISP script that is set to automatically run when each drawing is opened through acaddoc. This LISP basically adds a command for me to use as needed in Civil3D. But it would be beneficial if when opening a drawing, after loading the LISP, it automatically ran the command and answered all the prompts, as it should be exactly the same for every project I am working on. I'm not fluent whatsoever in LISP language so how would I go about adding these prompts to my acaddoc document?
Solved by hippe013. Go to Solution.
Can you post your lisp? And also post what the answer would be for each prompt? Maybe it can be re-written without any prompts at all.
I've attached the lisp file. This was received by another member today so I'm not familiar with the coding portion. The process I would like it to perform:
Run "QALL"
Enter Quantize Value: 0.001
Quantize objects even on locked layers?: Y
Add the following to the very bottom of the script that you posted.
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "QALL 0.001 YES ")
