PropertySet Formula Script to get vertice data from2d and 3d Polylines to provide as built information
ralstogj
ralstogj
Hi
I am trying to build a property set to attached to 3d polyline as built information using a formula using a script that will return the start and end point elevations, but to start with I am trying to just return the length. Below is what i have come up with to date. When I change activedrawing to thisdrawing in VBA to test it works but having no luck as a script just returns the whole script as text.
Does any have examples of doing this that they could share or know what could be wrong.
RESULT = "--"
On Error Resume Next
Set oApp = GetObject(, "AutoCAD.Application")
' Runs in AutoCAD 2021 with axdb24enu.tlb (must be referenced) AutoCAD/ObjectDBX Common 24.0 Type Library
Set oAutocadApp = oApp.GetInterfaceObject("ObjectDBX.AxDbDocument.24")
Set obj = oAutocadApp.ActiveDocument.HandleToObject([Handle])
RESULT = obj.Length
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
ralstogj
Hi
Got pointed in the right direction by this post
https://www.theswamp.org/index.php?topic=51871.0
Following code works for C#D 2021
Start Point
RESULT="--"
Set app=GetObject(, "AutoCAD.Application.24")
Set aec = app.GetInterfaceObject("AecX.AecBaseApplication.8.3")
aec.Init app
Set obj=app.ActiveDocument.ObjectIdToObject([ObjectID])
pt = aec.ActiveDocument.Utility.ConvertToVariantArray(obj.Coordinates)
RESULT = "X= " & pt(0) & " Y=" & pt(1) & " Z=" & pt(2)
End Point
RESULT="--"
aec.Init app
ptend = Ubound(pt,1)
RESULT = "X= " & pt(ptend-2) & " Y=" & pt(ptend-1) & " Z=" & pt(ptend)
Regards
Justin
Regards
Justin Ralston
