Dragging multiple civil cogo points at the same time.
I know a while back someone posted a lisp program to window a bunch of cogo points to drag them out.
https://forums.autodesk.com/t5/civil-3d-forum/dragging-multiple-labels-at-once/m-p/5745926#M279801
I'd like to window a bunch of points then drag them uniformly either by picking or by typing in an x or y distance.
Any help on this would be appreciated. Dragging the label of hundreds of cogo points is not fun.
Jeff_M
Dragging Point Labels via lisp is not directly possible. It would require a helper tool programmed in .NET. The link you posted had a .net solution but all the links are broken. It looks like Terry Dotson added a tool for this to his toolkit and I will be adding one to the Sincpac for the next release.
Jeff_M, also a frequent Swamper
That's too bad I also noticed all the links were broken. Let me know when you have that toolkit done I would love something to do this. Thanks
Jeff_M
The next release of the Sincpac will have the SPDRAGPOINTLABELS tool. You can either key in the X-Y offsets or select a cogopoint that has already been dragged to the desired offset.
https://knowledge.autodesk.com/community/screencast/6d9d3dd1-edc3-433f-a5e8-e7dbc50bf56a
That looks amazing.
Jeff_M
@Anonymous if you'd like to give it a try, shoot me an email at support AT quuxsoft DOT com
