Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
point number ranks.
3 REPLIES 3
joantopo
434 Views, 3 Replies
point number ranks.
joantopo
I have a method to create new point group.
In this method I add as parameter one vector which contains point numbers.
   string Numeros_Incluidos = "";
                        //buscamos todos los number point según su id y creamos una cadena string
                        foreach (uint NP in listaNumberPoints)
                            Numeros_Incluidos = Numeros_Incluidos + Convert.ToString(NP) + ",";
                        standardPointGrpQry.IncludeNumbers = Numeros_Incluidos;  //ejemplo: "550-560, 565-572"
                        //This method sets the query object in the point group
                        pointGrp.SetQuery(standardPointGrpQry);
 I create  a string called "Numeros_incluidos" that it is a chain of all numbers.
e.g:
"1,2,3,4,5,9,10,11,15,18,21,22,"
However I would like to create one function to create this string more organized as:
"1-5,9-11,15,18,21-22".
Any ideas?
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
point number ranks.
e.g:
Any ideas?
3 REPLIES 3
Jeff_M
in reply to: joantopo
Jeff_M
You can see what we use for the SincpacC3D in the free edition source code we've posted. Look in the PointListCreator.cs file.
Jeff_M, also a frequent Swamper
joantopo
in reply to: Jeff_M
joantopo
It´s right.
However,I think that all  methods in class(PointListCreator) should be in uint Type  instead of int(integer) because Civil 3D methods as "GetPointnumbers" returns a uint[] or "GetPointByPointNumber(uint value) use uint value.
It´s right.
Jeff_M
Jeff_M
@joantopo wrote:
It´s right.
I agree. That code was originally written for C3D2007 which used only the COM objects. The COM Database AeccPoint object returns the Number as an int so most everything in that FreeEdition code is based on that. As we've moved to a fully .NET managed package I've been updating all of the extensions accordingly.
@joantopo wrote:
It´s right.
Rail Community
