hi
i want to access the value of "Default Description" (picture attached) programmitically.
any help will be appreciated,
thanks in advance.
Solved by Jeff_M. Go to Solution.
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.Settings;
var civdoc = CivilApplication.ActiveDocument; var settings = civdoc.Settings.GetSettings<SettingsCmdCreatePoints>(); var s = settings.PointsCreation.DefaultDescription.Value;
