When you say you're getting unkown command, is that when you type the
shortcut or the actually command you assigned within the PGP? (May sound
like a silly question, but it may not be.)
Are you using REINIT to reload it?
Have you made sure that there aren't more than one ACAD.PGP in the support
folders? I think Acad loads the first one it finds, then ignores the rest.
wrote in message news:5375390@discussion.autodesk.com...
i recently customized my keyboard commands, and halfway through it i messed
it up, not sure what i did, but i had to create a brand new pgpfile and
recustomize it again... all is well except in the one file i was working in
when i screwed it up... it won't recognized certain commands like: bring to
front, send to back along with other commands, it will recocgnize the name
but say unknown command... any suggestions?
