Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Part Data map to Property Sets
14 REPLIES 14
Message 1 of 15
2341 Views, 14 Replies
Is there a way to map the material value (Reinforce Concrete) in part properties to property set.
any help please.
Result="--"
On Error Resume Next
Set oApp=GetObject(, "AutoCAD.Application")
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiLand.AeccApplication.12.0")
Set obj=oCivilApp.ActiveDocument.HandleToObject("[Handle]")
RESULT=obj.Material
any help please.
Result="--"
RESULT=obj.Material
14 REPLIES 14
Message 2 of 15
Civil3DReminders_com
Yes, it is possible. Do a search for Architecture (or MEP) and Property Sets and there are many code examples available. This code has how to get the part data: http://adndevblog.typepad.com/infrastructure/2012/09/how-to-set-pipe-network-parts-data-fields-partd...
There might be something on my blog if you want VBA, but I'm not 100% sure though.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Civil Reminders
Message 3 of 15
in reply to: Civil3DReminders_com
I found this https://forums.autodesk.com/t5/autocad-civil-3d-customization/get-pipe-material-from-code/m-p/254021....
How can i incorporate below code to the formula shown in the image? is that possible?
df = PartData.GetDataFieldBy(fieldname)
df.Value
Any help please.
df.Value
Any help please.
Message 4 of 15
Civil3DReminders
Civil3DReminders
RESULT="--"
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiLand.AeccApplication.11.0")
Set obj=oCivilApp.ActiveDocument.ObjectIdToObject("[ObjectID]")
RESULT=obj.PartDataRecord.FindByContext(300).Tag
You can find the list of standard Context here: http://blog.civil3dreminders.com/2016/03/freaking-context-values.html if you want to use a different value.
RESULT="--"
Message 5 of 15
This is what i'm looking for...Thanks you!!!!
Message 6 of 15
i have this list of context but i cannot find the context value for pressure pipe material. i tried the 300 for context value  but it only works for structure.
http://docs.autodesk.com/CIV3D/2014/ENU/API_Reference_Guide/html/96ac3273-fbeb-5752-d806-1e92a7e9d76...
Any Idea?
Any Idea?
Message 7 of 15
  public enum PressurePartContextType
    CatalogId = 700,
    PartType = 701,
    PartDomain = 702,
    PID = 703,
    PartFamilyId = 704,
    PartFamilyName = 705,
    IdType = 706,
    CompatibleStandard = 707,
    ConnectionPointCount = 708,
    Description = 709,
    DiameterNominal = 710,
    FidManufacturer = 711,
    IdCoatingInside = 712,
    IdCoatingOutside = 713,
    IdMaterial = 714,
    ModelName = 715,
    PressureClass = 716,
    PressureMax = 717,
    Schedule = 718,
    Sdr = 719,
    Series = 720,
    StrengthClass = 721,
    ThicknessClass = 722,
    Version = 723,
    ConnectionPointDeflection = 724,
    ConnectionPointEngagementLength = 725,
    ConnectionPointIdJointEndType = 726,
    ConnectionPointNominalDiameter = 727,
    ConnectionPointOuterDiameter = 728,
    ConnectionPointWallThickness = 729,
    IdTypeDescription = 730,
    PipeCutLength = 800,
    PipeDiamterInside = 801,
    PipeDiameterOutside = 802,
    PipeMinFlexRadius = 803,
    PipeThickness = 804,
    FittingAngle = 850,
    FittingBranchAngle1 = 851,
    FittingBranchAngle2 = 852,
    FittingCurveRadius = 853,
    FittingCutbackAngle = 854,
    AppurtIdSize = 900,
    AppurtOutCon1Dia = 901,
    AppurtOutCon2Dia = 902,
    AppurtOutCon3Dia = 903,
    AppurtIdCoolingMethod = 904,
    AppurtIdPowerRequirement = 905,
    AppurtIdPrimingMethod = 906,
    AppurtPrimingRequired = 907,
    AppurtValveActuator = 908,
Although I'm not sure if they will work.
Civil Reminders
    CatalogId = 700,
    PartType = 701,
    PartDomain = 702,
    PID = 703,
    PartFamilyId = 704,
    IdType = 706,
    Description = 709,
    IdMaterial = 714,
    ModelName = 715,
    PressureMax = 717,
    Schedule = 718,
    Sdr = 719,
    Series = 720,
    Version = 723,
    FittingAngle = 850,
    AppurtIdSize = 900,
Civil Reminders
Message 8 of 15
Thanks for the reply.
Not working.. maybe the Code is not right.
maybe the PartDataRecord is only for structure.
Message 9 of 15
If you can find the help file for AeccPressurePipesMgd I might be able to help figure it out. My Google with that help is failing me.
The above code will work with gravity pipes and structures.
Civil Reminders
Civil Reminders
Message 11 of 15
Message 12 of 15
Jeff_M
According to a post by,Partha Sarkar a few years ago, no help file has been developed for the PressuerPipes API due to it undergoing changes. https://forums.autodesk.com/t5/autocad-civil-3d-customization/aecc-appurtenance/m-p/4943688#M8961 and here we are, 3 years later, with pretty much the same thing.
Message 13 of 15
in reply to: Jeff_M
Does it mean that this is the dead end for pressure pipes.
Is there any other way to map the part data to property sets?
Message 14 of 15
Jeff_M
Jeff_M
I think that the problem you are running into is that no COM API for PressurePipes has been provided, only the .NET managed API. Therefor no InterfaceObject to get, so I don't know of any way to use PropertySets with PressurePipes.
Message 15 of 15
in reply to: Jeff_M
Thanks for all the reply,
I hope they develop a help file or just tell us what is the future for PressurePipes.
I searching on this forum an its been 4 years and counting that this situation occur.
Rail Community
