Good morning sir,
The commend " OFFSETFEATURE " is immensely using for our day-to-day work for pit design program.
Command: OFFSETFEATURE
Offset layer = Source
Specify offset distance or [Through/Layer]: 100
Select an object to offset:
Specify side to offset or [Multiple]: m
Specify side to offset:
Specify elevation difference or [Grade/Slope/Elevation] <0.000>: 600
- Specify offset distance or [Through/Layer]: 100 :
Here we required variable offset distance or through for each segment in the closed polygon.
This may be incorporated Please.
Thanking you sir.
