I am trying to obtain the index (integer) for TinSurfaceTriangle objects along with the (3) three index values of the vertices. These properties are not listed in the API however they do appear in the IDE watch window.
I've tried Reflection PropertyInfo and CallByName with no luck. I know I can use the coordinates of the vertices to find the index in the Points collection but that is slow even with BinarySearch on a sorted list (especially on extremely large TINs).
So if the IDE can show these values in the watch window, why can't we obtain them in code?
Hi, this is the way I use to get it:
First, using reflection, I get the PropertyInfo of the “Index" property. Then you get the value of that PropertyInfo referring to the vertex you want.
A few notes: This property isn’t available in the APi because it changes every time the surface is built or changed, so you need to be careful about that and prevent any changes to the surface while your code is running using the vertices indexes.
Also, beware that the vertices’ “Index”, which is an integer, may or may not be fully consecutive. I found this the hard way, trying to find a bug…
Here’s the code I’m using:
''' <summary> ''' Returns the PropertyInfo to use in GetIndex Extension Function (using reflection). ''' </summary> ''' <param name="vertex">The instance to which the method applies.</param> ''' <returns>The PropertyInfo corresponding to the Vertex Index.</returns> <System.Runtime.CompilerServices.Extension()> Public Function GetIndexPropertyInfo(vertex As TinSurfaceVertex) As PropertyInfo Dim arrayPropertyInfo() As PropertyInfo = vertex.GetType().GetProperties(BindingFlags.NonPublic Or BindingFlags.Instance) For Each prop As PropertyInfo In arrayPropertyInfo If prop.Name.Equals("Index") Then Return prop End If Next Return Nothing End Function ''' <summary> ''' Returns the vertex index in the surface (using reflection). ''' </summary> ''' <param name="vertex">The instance to which the method applies.</param> ''' <param name="IndexPropertyInfo">The PropertyInfo corresponding to the Vertex Index.</param> ''' <returns>The corresponding index.</returns> <System.Runtime.CompilerServices.Extension()> Public Function GetIndex(vertex As TinSurfaceVertex, IndexPropertyInfo As PropertyInfo) As Integer Return IndexPropertyInfo.GetValue(vertex) End Function 'SAMPLE USAGE 'get propertyinfo through reflection to gain access to the property index Dim propIndex As Reflection.PropertyInfo = SourceVertex.GetIndexPropertyInfo ' If we can't get propertyinfo then we can't find the index of the Vertex If propIndex.IsNull Then Throw New Exception("TinSurfaceVertex Index PropertyInfo not found.") End If 'get the indexes of the surface's vertices For Each vertex As TinSurfaceVertex In Surface.Vertices Dim index As Integer = vertex.GetIndex(propIndex) Next
that really helps. @david.silva @TerryDotson
would you please tell me how I can see the "Index" in the VSstudio. I cant see that in my IDE...
See my image at the top, in the IDE (only) the Index is a child of TinSurfaceTriangle and TinSurfaceVertex, it is not displayed under TinSurfaceEdge (your branch).
You can get the TinSurfaceVertex using several ways.
A few notes: Each Triangle has 3 vertices and as many edges. Each vertex can be common to several triangles but each edge may be common to 2 triangles at most and share 2 vertices from each triangle.
As I recall, when you get the triangle's vertices they'll be oriented CCW which means that you should be careful comparing edges because the same edge that separates 2 triangles will have different start and end vertices depending on which triangle you did get it from.
@TerryDotson : did my previous answer helped you? If so please mark this topic as answered. Thanks.
The Reflection.BindingFlags.NonPublic Or Reflection.BindingFlags.Instance parameters did get the Index and it matches the values displayed in the IDE. However there are two problems, one serious.
So thanks for the effort but for now I'm sticking with my existing BinarySearch method which gives consistently good results at a decent speed.
That was the issue I mentioned in the 1st answer, which took me a while to find a bug in my program. The vertices' index number may not match the TinSurfaceTriangleCollection index. It can start with indices 1, 2, 3 and then jump to 5 or 6. My guess is that it's related with the triangulation algorithm used (that may use auxiliary construction triangles/vertices) where some vertices that are outside the surface's boundary are discarded along the way and you end up having vertices indices greater than the number of vertices of the surface. Also these indices values may change each time the surface is rebuilt.
I ended up building my own TinSurfaceTriangleCollection with the number of vertices (count) equal to the index of the last surface's vertex and put each vertex in the collection's position according to its index. I agree this is quite a slow task. In my program (finding a least cost path along a surface with Dijkstra algorithm which is On2), building this collection takes about 70% of the time.
However, your question was how to find the vertex index property that showed up in the IDE.
True, but since they can't be trusted my problem isn't really solved is it?
I must say that your answer made me lose all interest in continuing contributing in this forum.
