Back in March, at Tony Tanzillo's prompting, I did find that C3D objects
could be accessed via ObjectDBX. I stated so at the time, but also said "Now
to find how to access the non-graphical objects, i.e. the Settings." I still
have not found a way to do this, and that, so far, is my only interest in
using ODBX with C3D. So, no, I have not found the answer that I want to
find.
So, you asked a blanket question, Peter gave a blanket answer. My previous
response to you about how you were extracting the information, was based
solely on what you said: "I can extract Civil3d Alignment, Profile,
ProfileView objects etc... from a closed drawing using objectDbx and then
transfer the information into another open drawing using VBA.". The key
wording here was "extract ..... objects", which is why I asked if you were
copying the objects to another drawing.
Now, if you would've been a bit more specific about WHAT you wanted to be
getting/doing, a more qualified response could likely have been given.
So, what solution have you arrived at?
Jeff
"jpkycek" wrote in message news:6241816@discussion.autodesk.com...
> Jeff Mishler,
> Have you figured it out yet?
> My original question was:
> "Can ObjectDBX
> be used to extract Civil 3d information
> from a drawing?"
> I said Yes!,
> Peter Funk said No!,
> I did not mention the type
> of data or objects from
> the ObjectDBX drawing or the
> method on how to get it
> because it is part of the Answer.
> What do you think the Answer whould be?
> Look outside the box.
