Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
need a shx any help would be awesome
7 REPLIES 7
Message 1 of 8
htls69
637 Views, 7 Replies
need this one
PVMT.shx
anyone that can help i with thank you a ton
Allen Robberson
Credit where credit is due! Give kudos or accept as solution whenever you can.
7 REPLIES 7
Message 2 of 8
JamesMaeding
in reply to: htls69
We could give you one, but it would be the blind leading the blind.
You have to show us the shape name used in the linetype asking for it, and what the shape should look like.
Maybe in a pdf from someone that had the shape.
Otherwise you will get what we guess the shape should look like, and you might as well just ask what our favorite color is (Blue obviously, if you want to pass).
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 3 of 8
htls69
in reply to: JamesMaeding
how can i delete it from the dwt we are using?
Allen Robberson
Message 4 of 8
JamesMaeding
in reply to: htls69
Its normally in a linetype, so you could delete it or redefine.
What I typically do is start a new drawing from the template, look at linetype names and remove ones like "pvmt edge".
Then close the session and re-open and see if I get the shx warning.
I call it, "divide and conquer" as you can remove 1/2 at a time or so and narrow things down.
What would really be nice is a lisp to show code for all linetypes in a dwg.
for that, you will need the attached lisp.
Load it and run command GETLTYPECODES.
Look for ones with PVMT and you have your culprit(s).
Enjoy!
Message 5 of 8
htls69
STILL NO LUCK
Allen Robberson
Message 6 of 8
JamesMaeding
in reply to: htls69
hmm, that template is almost a mb, yet it seems empty.
When I make a new drawing from it in 2015 (just acad, not map or civil3d), and save, the dwg is 68 kb.
I looked for blocks, linetypes, all kinds of stuff but its blank.
Is that supposed to be for civil3d? The styles should not have been purged by acad if so, and the size should be larger.
This is not a linetype issue it seems, and these shx issues get interesting fast when that is the case.
If you make a dwg from your template, and then a template from that dwg, do you still get a 1 mb file?
I don't, check out the dwt I came up with after round tripping like that.
Message 7 of 8
htls69
DANG I WAS LOADING THE WRONG ONE MY BAD THANKS
Allen Robberson
Message 8 of 8
JamesMaeding
in reply to: htls69
ok, I get a kudo. Come on, give it up Smiley Very Happy
Rail Community
