Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Lisp Point at Multileader vertex
11 REPLIES 11
Message 1 of 12
rjames94
551 Views, 11 Replies
How would I modify this lisp routine to add elevations to the points created. I would need the point z value set to the multileader content field. Attaching example file as well.
(defun LM:mleadervertices ( ent )
    (mapcar '(lambda ( x ) (massoc 10 x))
        (massoc "LEADER_LINE{"
            (cdr
                (assoc "LEADER{"
                    (cdr
                        (assoc "CONTEXT_DATA{"
                            (parsedxfdata (entget ent))
(defun massoc ( k l )
    (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= k (car x))) l))
(defun parsedxfdata ( l / foo )
    (defun foo ( / x )
        (setq x (car l)
              l (cdr l)
        (cond
            (   (or (null x) (= "}" (cdr x)))
                nil
            (   (and (= 'str (type (cdr x))) (wcmatch (cdr x) "*{*"))
                (cons (cons (cdr x) (foo)) (foo))
            (   (cons x (foo)))
    (foo)
(defun c:test ( / c e )
    (if
        (and
            (setq e (car (entsel "\nSelect mleader: ")))
            (= "MULTILEADER" (cdr (assoc 0 (entget e))))
            (setq c 1)
        (foreach l (LM:mleadervertices e)
            (foreach v l
                (entmake (list '(0 . "POINT") (cons 10 v) (cons 62 c)))
            (setq c (1+ (rem c 255)))
Tags (1)
Labels (3)
11 REPLIES 11
Message 2 of 12
hosneyalaa
in reply to: rjames94
@rjames94
try
            (cdr
                (assoc "LEADER{"
                    (cdr
    (defun foo ( / x )
        (setq x (car l)
              l (cdr l)
        (cond
                nil
            (   (cons x (foo)))
    (foo)
    (if
        (and
            (setq c 1)
            (foreach v l
                (entmake (list '(0 . "POINT") (cons 10 (list (car v) (cadr v) (atof (vlax-get (vlax-ename->vla-object e) 'textstring)))) (cons 62 c)))
Message 3 of 12
rjames94
in reply to: hosneyalaa
Works well, thank you. is there anyway to do this for multiple mleaders at a time?
Also some of the multi leaders result in an error. My guess is mleaders that have styles/expressions in the content field.
Message 4 of 12
hippe013
Run Strip MText Lisp Prior to running code provided by @hosneyalaa
Message 5 of 12
rjames94
in reply to: hippe013
Thanks that solved that issue!
Message 6 of 12
rjames94
When trying to modify the test function to grab a selection of objects (ssget) i get lenentityp errors. Any ideas to get the functions to all multiple objects to loop through instead of one object at a time?
Message 7 of 12
hippe013
Create a selection set using a filter. Then use SSNAME to return the entity from the selectionset. Something like this:
(defun c:test( / ss n c e)
  (setq ss (ssget '(( 0 . "MULTILEADER"))))
  (if ss
    (progn
      (setq n 0)
      (repeat (sslength ss)
	(setq ent (ssname ss n))
	(foreach l (LM:mleadervertices ent)
            (foreach v l
	(setq n (+ n 1))
  (princ)
Message 8 of 12
rjames94
I'm getting this
; error: bad argument type: lentityp nil
Is it because the other functions are using entget instead ssget,sslength,ssname etc. Do entget and ssget work together? Or should I convert the other functions to use ssget as well?
Message 9 of 12
hippe013
No. It is because in the version I posted I renamed the variable from "e" to "ent". Switching it back to "e" should solve the error.
  (if ss
    (progn
      (setq n 0)
        (setq e(ssname ss n))
          (foreach v l
	(setq n (+ n 1))
  (princ)
Message 10 of 12
rjames94
I got this error. ; error: bad DXF group: (62)
Removing "(cons 62 c)" solved that. But now i'm getting ; error: bad argument type: numberp: nil
Message 11 of 12
hippe013
Well. Removed entmake all together and removed the color index vaiable "c".
  (if ss
    (progn
      (setq ms (vlax-get-property (vlax-get-property (vlax-get-acad-object) 'ActiveDocument) 'ModelSpace))
      (setq n 0)
	(setq e (ssname ss n))
	  (foreach v l
	    (setq elev (atof (setq str (vlax-get (vlax-ename->vla-object e) 'TextString))))
	    (vlax-invoke-method ms 'AddPoint (vlax-3d-point (car v) (cadr v) elev))
	(setq n (+ n 1))
  (princ "\nDone.")
  (princ)
I tested this code to make sure that it works.
Message 12 of 12
rjames94
Thank you! Everything working as expected
Rail Community
