Is the command: _AeccProjectObjectsToProf It can be used through the lisp
hosneyalaa
Advisor Advisor
hosneyalaa
Hello all
I'm creating civil  point on  the   ALIGNMENT   when I click on the profile  Using the lisp
Is it possible to show this point on the profile through the command AeccProjectObjectsToProf
this is lisp
(defun c:test ( / ELEV ENT ENTALIGNMENT: OBJ PNT POINTLIST PT PTLIST PTLST STA TESTPNTTT VLAOBJ X Y)
(vl-load-com)
  ;;;  Jeff Mishler
       (defun getC3D	()
    (vl-load-com)
    (setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
		      (if vlax-user-product-key
			(vlax-user-product-key)
			(vlax-product-key)
	  C3D (vl-registry-read C3D "Release")
	  C3D (substr
		C3D
		1
		(vl-string-search
		  C3D
		  (+ (vl-string-search "." C3D) 1)
	  C3D (vla-getinterfaceobject
		(vlax-get-acad-object)
		(strcat "AeccXUiLand.AeccApplication." C3D)
    (setq C3Ddoc (vla-get-activedocument C3D))
   (getC3D)
  (setq points (vlax-get C3Ddoc 'points))
  (setq ent (entsel "\nSelect profile view:"))
  (setq obj (vlax-ename->vla-object (car ent)))
  (setq vlaobj (vlax-get-property obj 'parent))
  (while
   (SETQ pt (GETPOINT "\n-> Specify a point :"))
(progn
(vlax-invoke-method obj 'FindStationAndElevationAtXY (CAR pt) (CADR pt) 'sta 'elev 'inside);; OK
(setq testpnttt (list sta elev));;OK
               (vlax-invoke-method vlaobj 'PointLocation sta 3 'x 'y)
                (setq pntAL (list x y));;OK
            (setq oCogo(vlax-invoke points 'add (LIST (car pntAL) (cadr pntAL) elev)))
;;;; command: _AeccProjectObjectsToProf
(princ));;;;
thank you
hosneyalaa
HI MR @Jeff_M
Is it possible to show CIVIL  points on the profile?
ProjectObjectsToProf  BY the LISP
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXLandLib__IAeccProfileProjection...
