I need help making a special linetype.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey!
Im supposed to make a special linetype, but i cant get it right, and im not sure im doing it with the right method, im not that good with CAD, only with the basics.
Im supposed to make a linetype that looks like the pic i posted.
It supposed to represent a sewer pipe, and its global widht supposed to be the circumference of the pipe.
I made this linetype using a shape (MKSHAPE), and then made a linetype outof it (MKLTYPE).
The porblems:
-the insert and starting point is sopposed to be the yellow dot. When i made the linetype i clicked there, but it stills ad a little line at the beggining, and only starts the linetype after that. How can i make it start always with the rectangle?
-when i change the global widht its only chnages the widht of that small line (you can see on the pic). I want the global widht to be the distance between the top and the bottom of the rectangle (the red line). How can i set that up?
Is there any way to make a linetype, or any other way (maybe block) to make this happen?
