Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
How to start using the Civil 3D API with C#?
4 REPLIES 4
alexander_07_11
150 Views, 4 Replies
Hi everyone. I post here cause I don't know how to start learning to use the C3D API to create commands. I'm not new to programming, as I've used Python and also I'm capable in Dynamo for C3D, but I know that the C3D API is a lot more powerful. I hope you can guide me or recommend where can I learn or how to start. Wish I'm not breaking any rules posting this here. Thanks in advance.
4 REPLIES 4
@alexander_07_11
To create a new project that uses the Autodesk Civil 3D managed classes in Microsoft Visual Studio
https://help.autodesk.com/view/CIV3D/2025/ENU/?guid=GUID-DE3A46DA-508E-43A0-8538-C77D978D06B2
hi, as @hosneyalaa  mentioned the C3D documentation is the best way to start with, first just try all examples in documentaions and try to tweek it and play arround with it , then try to solve your own problem, and if get stuck you can post here.
good luck
Jeff_M
in reply to: alexander_07_11
There are a few sample projects that are installed with Civil 3D:
C:\Program Files\Autodesk\AutoCAD 2024\C3D\Sample\Civil 3D API\DotNet\CSharp
Thank you very much for your responses. I'm starting out using the sample project that comes with C3D. I hope I can make it. Thanks again
Rail Community
