Attached is a compiled DLL in a zip file. After downloading be sure to go to the ZIP file's properties and Unblock the zip, otherwise the extracted dll won't load. Also providing the c# code, which should be valid for C3D 2013-2016.
/// Created by Jeff Mishler
/// Quux Software LLC
/// http://www.quuxsoft.com
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.DatabaseServices;
namespace Civil3D_Misc_Commands.SectionViews
public class SectionViews
[CommandMethod("SVMinMax")]
public void svminmax()
try
SVMinMaxcommand();
catch
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("****Uh oh! This command is unable to be used in C3D 2013 or older!****");
finally
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nThis Utility brought to you by: Quux Software, creators of the Sincpac-C3D.");
private void SVMinMaxcommand()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
double min = Double.MinValue, max = Double.MaxValue;
PromptSelectionOptions ssOpts = new PromptSelectionOptions();
ssOpts.MessageForAdding = "Select SectionViews to adjust Min/Max values:";
ssOpts.MessageForRemoval = "...Select SectionViews to remove from selection:";
ssOpts.RejectObjectsOnLockedLayers = true;
TypedValue[] tv = { new TypedValue(0, "AECC_GRAPH_SECTION_VIEW") };
SelectionFilter filter = new SelectionFilter(tv);
PromptSelectionResult ssRes = ed.GetSelection(ssOpts, filter);
if (ssRes.Status != PromptStatus.OK)
return;
PromptDoubleOptions dOpts = new PromptDoubleOptions("\nEnter new Minimum elevation for sectionviews:");
dOpts.AllowArbitraryInput = false;
PromptDoubleResult dRes = ed.GetDouble(dOpts);
if (dRes.Status != PromptStatus.OK)
return;
min = dRes.Value;
dOpts.Message = "\nEnter new Maximum elevation for sectionviews:";
dOpts.DefaultValue = min + 1;
dOpts.UseDefaultValue = true;
return;
max = dRes.Value;
while (max < min)
dOpts.Message = "...Max must be higher than Min, try again:";
return;
max = dRes.Value;
using (Transaction tr = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
foreach (ObjectId id in ssRes.Value.GetObjectIds())
SectionView sv = (SectionView)id.GetObject(OpenMode.ForWrite);
if (sv.IsElevationRangeAutomatic)
sv.IsElevationRangeAutomatic = false;
sv.ElevationMax = max;
sv.ElevationMin = min;
tr.Commit();
