How to Edit Elevation (Min and Max) in Section View
Message 1 of 36
I tried to edit the Elevation Minimum & maximum in the GRAPH_SECTION_VIEW  using following lisp program,
but getting a error  " ; error: Invalid number of parameters "
(defun c:MMElevation()
(vl-load-com)
(if (setq SelEntobj (ssget "+.:S:E" '((0 . "AECC_GRAPH_SECTION_VIEW"))))
(progn
(setq EntObj (ssname SelEntobj 0))
(setq ObjName(vlax-Ename->Vla-Object EntObj))
(setq ElevationMin (vlax-get ObjName 'ElevationMin))
(setq ElevationMax (vlax-get ObjName 'ElevationMax))
(if (> ElevationMin 0.0)
(progn
(vlax-put ObjName 'ElevationMin 0.0)
(vlax-put ObjName 'ElevationMax (- ElevationMax ElevationMin))
(alert "No Object Selected")
(princ)
Replies (35)
Message 2 of 36
Jeff_M
@Anonymous, Welocme to the forums! For future posts with code, use the Code button and paste the code into the window provided. This will prevent the forums from placing smiley faces in the code Smiley Happy
The SectionView elevation and offset properties are read only in COM/ActiveX, so cannot be done in lisp. Using the .NET API you are able to set the Automatic/User SPecified toggle for the elevations and offsets, as well as change the values used. I have a similar function I created to set all sectionviews to use the same min/max values, it is written in c# if you are interested in going that route.
Message 3 of 36
Thanks jeff for your information,
Can I get the tool or code.
if code means then I can update as per the requirement and I don't have
much knowledge in c#. And I am a beginner in vb.Net
Message 4 of 36
Jeff_M
Attached is a compiled DLL in a zip file. After downloading be sure to go to the ZIP file's properties and Unblock the zip, otherwise the extracted dll won't load. Also providing the c# code, which should be valid for C3D 2013-2016.
/// Created by Jeff Mishler
/// Quux Software LLC
/// http://www.quuxsoft.com
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.DatabaseServices;
namespace Civil3D_Misc_Commands.SectionViews
    public class SectionViews
        [CommandMethod("SVMinMax")]
        public void svminmax()
            try
                SVMinMaxcommand();
            catch
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("****Uh oh! This command is unable to be used in C3D 2013 or older!****");
            finally
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nThis Utility brought to you by: Quux Software, creators of the Sincpac-C3D.");
        private void SVMinMaxcommand()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            double min = Double.MinValue, max = Double.MaxValue;
            PromptSelectionOptions ssOpts = new PromptSelectionOptions();
            ssOpts.MessageForAdding = "Select SectionViews to adjust Min/Max values:";
            ssOpts.MessageForRemoval = "...Select SectionViews to remove from selection:";
            ssOpts.RejectObjectsOnLockedLayers = true;
            TypedValue[] tv = { new TypedValue(0, "AECC_GRAPH_SECTION_VIEW") };
            SelectionFilter filter = new SelectionFilter(tv);
            PromptSelectionResult ssRes = ed.GetSelection(ssOpts, filter);
            if (ssRes.Status != PromptStatus.OK)
                return;
            PromptDoubleOptions dOpts = new PromptDoubleOptions("\nEnter new Minimum elevation for sectionviews:");
            dOpts.AllowArbitraryInput = false;
            PromptDoubleResult dRes = ed.GetDouble(dOpts);
            if (dRes.Status != PromptStatus.OK)
                return;
            min = dRes.Value;
            dOpts.Message = "\nEnter new Maximum elevation for sectionviews:";
            dOpts.DefaultValue = min + 1;
            dOpts.UseDefaultValue = true;
                return;
            max = dRes.Value;
            while (max < min)
                dOpts.Message = "...Max must be higher than Min, try again:";
                    return;
                max = dRes.Value;
            using (Transaction tr = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
                foreach (ObjectId id in ssRes.Value.GetObjectIds())
                    SectionView sv = (SectionView)id.GetObject(OpenMode.ForWrite);
                    if (sv.IsElevationRangeAutomatic)
                        sv.IsElevationRangeAutomatic = false;
                    sv.ElevationMax = max;
                    sv.ElevationMin = min;
                tr.Commit();
Message 5 of 36
Hi Jeff,
Sorry for the late reply, Thanks & Your tools works really great.
Message 6 of 36
Jeff,
Just found your solution.  Svminmax.dll works great on Civil 3D 2014.  Thanks!
Greg
Message 7 of 36
Thank you so much!!!!! WORK IN CIVIL3d 2018 AS WELL
Message 8 of 36
I'm a beginner when it come to dll file. Could please show me how to use this? Thanks
Message 9 of 36
Jeff_M
Download the ZIP file, Unblock it as described above, save the DLL to a location you know, in C3D us ethe NETLOAD command, browse to the DLL and load it. Then the command SVMINMAX will (should) be available.
Message 10 of 36
Thanks Jeff! It works wonder!!
Message 11 of 36
Hi, Thanks for the command it is very useful indeed!
Another thing though, Can i have a modified version of this that the Maximum Elevation will set at "Minimum + 10", as on our work pattern the Section View Graph is set to 10 unit height, so no need to input the maximum value. Can be set at different command like "SVHt". By this we will input Minimum Elevation only every time we run the command.
Thanks a lot in advance!
Message 12 of 36
Jeff_M
@Anonymous Attached is an updated DLL which includes the new command SVHT. When selecting the SectionViews you can use the SEttings option to set the height above minimum elevation which is saved for future running of the command. The default is 10.
Message 13 of 36
sbrasher
You are my HERO!!! The lack of this kind of tool in C3D has driven me crazy for years and I can't believe how well your dll works!! THANK YOU, THANK YOU, THANK YOU FOR SHARING IT!!!
Message 14 of 36
leon.smolic
Is there a dll for manipulating Offset also? - it would be greatly appreciated if anyone has one and want to share.
Message 15 of 36
thank you. I use in c3d 2020
Message 16 of 36
thank you. i use in c3d 2020
Message 17 of 36
Jeew-m
This saves my day..... Thanks @Jeff_M
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 18 of 36
john.uhden
Hi, @Jeff_M ,
I am still at best stumbling along in learning C3D.
I noticed the 'ElevationMin object property when I dumped a profile view and it didn't say (RO), but vlax-putting the property failed.
Is there another "normal" way to raise the bottom of a profile view?  I have lots of wasted space taken up by nothing but grid lines.
John F. Uhden
Message 19 of 36
Jeff_M
@john.uhden the 'normal' method is to allow automatic elevations and setting the grid padding in the SectionView Style to a smaller value. To modify the ElevMin/Max values requires 2 things...the IsElevationRangeAutomatic property must be set to false and you must be using the .NET API since the Elev* properties in COM are read only and that needed property isn't even available:
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXLandLib__IAeccSectionView.htm
Message 20 of 36
john.uhden
@Jeff_M
Many thanks, Jeff.
Luckily I made another quick profile and the base elevation came out
satisfactory, so the problem has gone away for now.
John F. Uhden
