Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
How do debug XSL
1 REPLY 1
503 Views, 1 Reply
How do debug XSL
How to I debug XSL files?
I tried to modify the FormatNumber function on NumberFormatting.xsl to change the decimal separator from period to comma.
	//This was the original code:
	return rNumber.toString();
	//I changed to this
	//return Replace(rNumber.toString(), ".", ",");
Also tried writing replace in lowercase.
I tried adding the replace function in earthworks.xsl:
<xsl:value-of select="landUtils:FormatNumber(string(0.0), string($SourceVolumeUnit), string($Earthwork.Volume.unit), string($Earthwork.Volume.precision), string($Earthwork.Volume.rounding))"/>
<!-- <xsl:value-of select="replace(landUtils:FormatNumber(string(0.0), string($SourceVolumeUnit), string($Earthwork.Volume.unit), string($Earthwork.Volume.precision), string($Earthwork.Volume.rounding)),'.',',')"/> -->
In all three cases the result was a blank page in the browser.
Greetings from Paraguay.
Claudio Bogado Pompa.
1 REPLY 1
tyronebk
You need to format your method call like this:
return rNumber.toString().replace(".", ",");
replace needs to be called with "dot notation" and with all lowercase letters.
Rail Community
