Help in Alignment From Network Parts Using C# ?
y.awwad
y.awwad
I have a C3D Storm Network File , I want to create alignments from network parts and create profiles for created alignments , Test File Attached
if you can help @Jeff_M  🙏
Replies (10)
Jeff_M
@ Have you tried the CreateAlignFromNetwork command?
y.awwad
Yes ,but this is a manual method .. i ask for a C# code , i searched but didn't find Alignment from network parts in documentation
Jeff_M
@y.awwad your initial post did noy mention anything abut c# code. Neither post suggests how you want it to work, nor do you show any code that you have created to attempt this project. If you want someone to create it from scratch for you, at the very least you would need to explain the steps you would expect to take when executing the command.
hosneyalaa
@y.awwad  hi
Why delete your code in your first post
It's better to repost it as  @Jeff_M said
y.awwad
@hosneyalaa
That code was generated using AI and was not working so i thought people will laugh when see the code  🙄
y.awwad
@Jeff_M
sorry , I just mentioned in title ( using C# )
I just need a guide if there is a C# Method to do same steps as ( Create Alignment From Network Parts ) because I searched in documentation but all I found was alignment in general of from polyline ( without any structure selecting )
Steps For Creating an Alignment :
Select last ( structure ) then first  ( structure )  , it will automatically select all structures and pipes between them and add all to the created alignment
Jeff_M
@y.awwad The Network Object has the FindShortestNetworkPath method which returns the ObjectIds of the parts in that path. You can use the coordinates of the pipes and/or structures to add the segments of the Alignment (create an Alignment without geometry) by adding a FixedLine segment to the AlignmentEntties.
y.awwad
@Jeff_M
Thanks for help 💙
y.awwad
when create Alignment from polyline, its type be "Centerline"
I want to change alignment type to "Miscellaneous" , plz help  @Jeff_M  🙏
I tried but i got error that Alignment Type is read only
in civil 3D i can manually open Alignment properties and select type to "Miscellaneous"
https://help.autodesk.com/view/CIV3D/2020/ENU/?guid=a11fcbba-1e90-ad37-d265-2243da4da299
Jeff_M
@y.awwad As you have found, the AlignmentType is read only. So the Civil 3D developers have decided that we 3rd party programmers won't ever need to set this. Sounds like a shout out to @TimYarris & @dsimeone is in order to maybe get this remedied.
Type a product name
