Hi everyone,
I'm currently facing a challenge in my road project using Civil 3D, and I need some help with implementing formula properties. My project involves designing road layers with specific thicknesses, defined in the cross-section components of the road. I'm looking to transfer these thickness values to the 3D solids created from the corridors.
The process I'm following is:
I create 3D solids from the corridors.
During this creation, I automatically obtain properties from the referenced cross-sections.
My objective is to use these properties to extract the thickness values of the road layers from the cross-sections and then add these values to the properties of the corresponding 3D solids. I think the formula properties using VBA script should be the right way, but I am not really familiar with that.
Thank you in advance for your help and support!
Best regards,
Anton
