Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
FindXYAtOffsetAndElevation API Via Lisp Fail
7 REPLIES 7
Message 1 of 8
davilavanegas
1645 Views, 7 Replies
I am trying to use FindXYAtOffsetAndElevation for SectionViewObject via Lisp, but it fail.
I get error: ActiveX Server returned the error: unknown name: FindXYAtOffsetAndElevation
Instead when a use FindStationAndElevationAtXY I get correct result.
(defun offelev ( obj off elev / x y point)
  (vlax-invoke-method obj'FindXYAtOffsetAndElevation 'off 'elev)
  (setq point (list off elev))
;;example
(setq ent (car (entsel "\nSelect SectionView"))
      obj(vlax-ename->vla-object ent)
      off (vlax-get-property obj 'OffsetLeft)
      elv (vlax-get-property obj 'ElevationMin)
(offelev ojb off elv)
______________________
RDV - Rinat Dávila Vanegas  | LinkedInYouTube | Facebook
7 REPLIES 7
Message 2 of 8
GTVic
in reply to: davilavanegas
Functions with station in the name are for Profile Views. Maybe show the calling function.
.NET API
SectionView.FindOffsetAndElevationAtXY
SectionView.FindXYAtOffsetAndElevation
ProfileView.FindStationAndElevationAtXY
ProfileView.FindXYAtStationAndElevation
Message 3 of 8
Jeff_M
The method you are specifying does not exist. Try this:
(defun offelev ( obj sta off elev / x y point)
  (vlax-invoke-method obj 'FindXYAtStationOffsetAndElevation sta off elev 'x 'y 'inside)
;;example
      elev (vlax-get-property obj 'ElevationMin)
      sta (vlax-get (vlax-get obj 'parent) 'station)
(offelev obj sta off elev)
Jeff_M, also a frequent Swamper
Message 4 of 8
Jeff_M
in reply to: Jeff_M
I dont know why my reply posted twice. Nor do I know why Autodesk thought the Station was needed since the SectionView selected is the one being worked with.
Message 5 of 8
Thanks @Jeff_M,
I was looking 'FindXYAtStationOffsetAndElevation at http://docs.autodesk.com/CIV3D/2019/ENU/API_Reference_Guide/index.html and its is not expose.
Another question, ' inside arguments which mean? At API help this is not show.
Message 6 of 8
hosneyalaa
thank you sir @Jeff_M
Hello @davilavanegas
you was looking 'FindXYAtStationOffsetAndElevation at use lisp
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXLandLib__IAeccSectionView__Find...
Message 7 of 8
davilavanegas
in reply to: hosneyalaa
Thanks @hosneyalaa,
I am clear Rightnow. I Could use pInBounds to ckecks if is insdide section view limits.
Message 8 of 8
hosneyalaa
I'm sorry, I don't have an answer ,master  @davilavanegas
But the master @Jeff_M
He has the solution to all problems, and I learn from him
Rail Community
