Feature Line Analysis - Change in grade
This widget could not be displayed.
Would there be a way to to automate the analysis of feature lines or 3D polylines to place a block on all nodes where the change from incoming slope to the outgoing slope exceeds a specified value?
Civil3DReminders_com
Yes.
For Feature Lines you'd use the methods found in this link:
http://docs.autodesk.com/CIV3D/2016/ENU/API_Reference_Guide/html/856470c7-bf8f-2fa4-db5f-d290252f36c...
For 3D Polylines I'd look at this post:
https://through-the-interface.typepad.com/through_the_interface/2007/04/iterating_throu.html
Here's how to create a block:
https://through-the-interface.typepad.com/through_the_interface/2010/01/creating-an-autocad-block-us...
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Jeff_M
The code I posted in this forum post years ago may help:
https://forums.autodesk.com/t5/civil-3d-customization/example-c-code-to-temporarily-show-high-low-po...
